    Changing number of columns in Speed Dial
      sgrandin last edited by
      What does it take to get 6 columns in x64? Install of separate x64 beta version is showing 5 columns in Speed Dial while my x32 version shows 6 and settings in both are for 6. Entering the Konami code doesn't draw any response, but I seem to recall that another method replaced it sometime back. What's the trick? Thanks,
        browzer1 last edited by
        CTRL plus + or -.
          The Konami code should work, but you need to click outside the search field. Having said that, the only related setting is an Advanced setting (checkbox at the bottom of Settings page) and not a Power User setting (Konami code).
            Steve, browzer1's is the correct solution. Konami code just doesn't work anymore. I think that was the change several versions back.
              Power User mode doesn't give you a relevant option regardless. The only relevant option in Settings is under Advanced options.
                But advanced options is not a setting for a specific number of columns per se but a max. I did get Konami code to work by ending in little b-a instead of caps, the latter showing in the Wikipedia entry.
