    Problem with RevolverMaps in Opera
      jaryn237 last edited by
      Hello,
      on this website does not display a RevolverMap left under column "Galerie - Gallery":
      http://nikolmarisbabiesgallery.mypage.cz
      This problem is only in OPERA, in another browsers I do not have this problem.
      Do I need a plug-in?
      Thank you very much.
        Try disabling the ad-blocker for that page.
          Blocked by the ad-blocker, of course. Not exactly an ad, but it is a tracker so it gets blocked anyway. The user could unblock it on that site if they wished, but the website can't do anything on their end. If you want to see the map, then click on the blue badge on the right side of the address bar and disable the ad blocker for that site, then reload the page.
            Thank you!! It is OK. I thought it is only a small detail... 🙂
