    How do I select my preferred no. of speed-dial columns?
      sofloc last edited by
      Note, the question is not how to select the maximum no. of columns, what is under settings, but seems not to affect the actual no. of columns displayed.
        There is no such setting currently afaik.
          A Former User last edited by admin
          You might consider taking a look here 🙂
            Ok, so some no. of columns, depending on screen, is just displayed without the user selecting. May I suggest columns are too broad generally; I'd prefer more columns (and to be able to select, actually would prefer this all as in much-earlier versions 🙂 including no bogus design of dials).
              No, ok, I see now, Zoom does it with the no. of columns!
