    Sync same Speed Dial on every device
    56
    104
    140146
      why they removed this feature ?
      It was never implemented in Opera Chromium.
        morectus last edited by
        support 100%
        I want thesame speed dial on my laptop than on my desktop.
        this function can only make opera better.
        with the box of letting them chose ofc.
          Excellent request.
          I want this feature too.
          C'mon chropera team!
            This is exactly what Opera needs!
              lokipuk last edited by
              Agreed, totaly hate not to be able to sync speed dials!!
                Based off the lack of response the "simple" addition of this feature is likely more difficult than we are imagining. Anyone have an idea as to why it's more complicated than we're imagining?
                  leocg Moderator Volunteer @Guest last edited by leocg
                  @wkershner First, you should not expect responses from Opera, specially about suggestions an requests.
                  Second, we don't even know if they even started thinking about implementing it.
                  Reply Quote -1
                    R 1 Reply Last reply
                    Yes, I agree, this feature is lacking in Opera and needs to be addressed. Cheers
                      This feature would be really useful because I would like some of my devices to share the same Speed Dials but some have their own ones. Unfortunately right now I have like a million separate Speed Dials )
                        I've managed to make that work.
                        2 computers 1 SpeedDial.
                          I agree that this could be an option for synchronization.
                          But I strongly disagree this being a default behavior, i.e. not having speed dials folders as it is now. The way it is now is the exact behavior as I would expect and a top implemented feature. I don't want the same speed dials on my work and home PC, and actually need third set for my phone.
                          I wanted to try the new Firefox Quantum and had a terrible time making it work like this with the Top Sites similar to Opera Speed Dial feature.
                          Reply Quote -1
                            I use different profiles for
                            • Home
                            • Study
                            • Work
                            Then, to share the same SD it's much more comfortable.
                            But as said, that would be a decision to leave to the user.
                              "Then, to share the same SD it's much more comfortable."
                              So if you want to study at home, or do a little work, or have a look at the link you need at work but set it at home you need to switch profile every time?
                              "But that, would be a decision to leave to the user."
                              Definitely.
                                zalex108 1 Reply Last reply
                                @maxdule said in Sync same Speed Dial on every device:
                                Yes, I do.
                                At home I have each profile to use for those purposes.
                                In case I've found a new link on the home profile, I just copy/paste it to the needed profile or send it to the email or share it with dropbox.
                                I've found that more convenient to keep all clean and organized.
                                  "In case I've found a new link on the home profile, I just copy/paste it to the needed profile or send it to the email or share it with dropbox.
                                  I've found that more convenient to keep all clean and organized."
                                  Maybe you need a "Slow Dial" feature instead. 😂
                                    xDDDD
                                    🐢 Dial
                                      zalex108 @zalex108 last edited by zalex108
                                      Recently found TeamSync Bookmarks, slowness solved. :smiling_face_with_open_mouth_smiling_eyes:
                                        rooneyandmuldoon @leocg last edited by rooneyandmuldoon
                                        @leocg said in Sync same Speed Dial on every device:
                                        @leocg I'm thinking Opera should not expect me to keep using their browser, due to lack of concern or help from Opera about problems.
                                          A Former User @rooneyandmuldoon last edited by
                                          Is there anyone here not from Opera software that can explain what the programming problem is with syncing speed dials?
                                          I don't buy at all "everyone wants different speed dials on every device". That's bs. Nobody does.
                                          What's the real story here? Is this too big of an issue for Opera Soft to program ? 800 billion options in opera and they can't program the #1 request by users of all time?
                                            @btabke Some people want to have the same speed dials on all devices while others prefer to have different ones for home and work for example, so people at Opera decided to give users speed dial sync but not automatically populated each start page with synced speed dials.
