    Synchronization has encountered a problem
    13
    2708
      LearnTheCube last edited by
      Synchronization is not working on my browser. Under my profile tab, it says "Synchronization has encountered a problem" and clicking on it only brings me to sync settings.
      There was a previous post with the same topic, but the problem was not resolved! Please advise on fixes. Thank you.
        leocg 2 Replies Last reply
        leocg Moderator Volunteer @LearnTheCube last edited by
        @LearnTheCube Opera One, Opera GX or Opera Air?
          @LearnTheCube Did you try logging out and logging in again?
            AntSpy last edited by
            Same issue here.
              If you goto the URL opera://sync-internals, does it give you more information about the error (after you start Sync and trigger get updates)?
                Rhadazeroz last edited by
                same issues cannot sync and i logout and log in and in opera for windows desktop always say login to perfom sync but never sing in
                in opera mobile android the issue not appear
                other image
                opera version 127.0.5778.76 and if you go to web to tab sync always is like the image
                I have two accounts and all the same issue
                  i have more screenshots to describe de error, appear cannot sing in into pc client
                    more error I have using opera://sync-internals
                    I triend to login into client and same error, but using web can log in but sync area still waiting circle....
                    Summary
                    Transport State Disabled
                    User Actionable Error Needs settings confirmation
                    Actionable Error
                    Error Type NOT_MY_BIRTHDAY
                    Action DISABLE_SYNC_ON_CLIENT
                    Error Description
                    I think the problem is the program opera cannot get the credentials and cannot sing in the account
                      Kon-Tiki last edited by
                      Same issue.
                      If go to https://www.sync.opera.com there infinite circle after auth
                        AntSpy @burnout426 last edited by
                        @burnout426
                        I'm with the same as the other guy
                          It should be working now
                            Reteipa last edited by
                            Trying for 45 minutes to sync between two laptops. Well, forget it. Simply doesn't work.
                            Using Opera for years now, just got a second laptop (lovely gift).
                            How easy would it be to sync between laptop A and laptop B (bookmarks only).
                            Takes for ever to figure out what a passphrase is. It only leads me to a video where a way to cheerful lady says: "Just log in and all devices have the same bookmarks". No it doesn't work like that.
                            So I used a USB stick to export all bookmarks, put it in laptop B, and imported it.
                            Took 10 seconds.
                            The only reason I'm sticking with Opera because I don't like Chrome.
                            Sync is a worthless feature.
                              B 1 Reply Last reply
                              beacon07 @Reteipa last edited by
                              @Reteipa Opera has never fixed synchronization lol. I stopped syncing 2 years ago because of the passphrase nonsense. Tried to sync again today to see if they fixed that bug and the answer is NO! 😂 They still need a passphrase I never set even though I am set to sync with google account and as mentioned above they'll randomly log you out of the account hence disrupting the synchronization ever so often.
