    Emoji window not fully displayed when setting emoji for workspace
    3738
      Kelandor last edited by leocg
      Hi! Hope you are doing well.
      Would it possible to fix this?
      Thank you for your attention for this matter.
        leocg Moderator Volunteer @Kelandor last edited by
        @Kelandor And what would be the bug? You forgot the most important information in your post.
          K 1 Reply Last reply
          Kelandor @leocg last edited by
          @leocg Thank you for your reply, the emoji Window is not fully displayed
            sancron last edited by
            Hello,
            when i try to select a custom Emoji for an Icon in for an Workspace. I can't really choose one. I do not know when this was issue was introduced but with the latest Update it still consists:
            Used Version:
            LVL 7
            122.0.5643.52
              MiguelVilar last edited by
              Has a solution been found for this issue yet?
              • Ramanuta
                Ramanuta last edited by
                This was not a issue before, why is this suddenly a issue? I hate this, i want to make a new workspace and this is making it really annoying. Why are not more talking about this issue? Has anyone found a solution yet?
                Ramanuta | Peter Martin Ledergerber | Technology Enthusiast & Creative Spirit
                "Always one step further in the world of technology and creativity"
                🌊 Swimmer | 🎮 Gamer | 🤖 AI Fan | 🏹 Archer
                  Kelandor @Ramanuta last edited by
                  @Ramanuta look like no one care, it says a lot about "QA\QC", anyway - you can edit it in preferences file or you can create all needed workspaces in classic opera and than copy-paste preferences file. Please do backup before do anything.
                    Ramanuta 1 Reply Last reply
                  • Ramanuta
                    Ramanuta @Kelandor last edited by
                    @Kelandor This is yet another issue with this system — why do we always have to find stupid workaround solutions for problems we didn’t even cause?
                    It’s honestly unbelievable that we have to fix these things ourselves while they do nothing to resolve them.
                    This particular issue has been around for over two weeks now, and they clearly don’t care. Even when problems like this are reported, they only get fixed if thousands of people complain.
                    The simplest solution to this would be to give us the ability to manually move the sidebar and/or the emoji window.
                    Right now, we can’t even move the sidebar to the right side if we wanted to, or adjust its width like we can with other side-windows such as Discord or the music player. That alone would immediately fix this entire issue.
                    Anyway, thanks again for your helpful advice — it worked for me, and I was finally able to create the workspace I wanted.
                      @Ramanuta You are right, and I feel you. However, it is what it is. These bugs aren’t worth your nerves. I’m glad my message was helpful to you. Kind regards!
                        Y 1 Reply Last reply
                      • Y
                        YourMomIsHotlol @Kelandor last edited by
                        @Kelandor Hi! Unsure if you have already found a solution or have tried this yet . But just incase! I have found restarting your device has fixed this problem at least for me. Not sure if it will help for all devices
