    Speed Dial Synchronization
    syncronization speed dial
      namenlos1488 last edited by
      I have two laptops - old one and new one. I've and enabled speed dial synchronization on both devices. Now i can see the content of speed dial from the old laptop on the new one in a separate bookmarks folder. But i don't want it to be a bookmarks folder - i want the speed dial on the new device have the same content as on the old one. How to do it and is it even possible?
        leocg Moderator Volunteer @namenlos1488 last edited by
        @namenlos1488 As said, you need to manually move them from Other Speed Dials to Speed Dials
          N 1 Reply Last reply
          namenlos1488 @leocg last edited by namenlos1488
          @leocg You mean just select all content of said folder, copy selection and paste into speed dial? It works, thanks for suggestion. But it doesn't make them actually synchronized - if i then add or remove something in speed dial of one laptop, these changes do not affect speed dial of another. So they can't actually be synchronized?
            @namenlos1488 They are synchronized but not automatically populated.
