    Reduce Clutter: Optimize GX Corner for Multi-Window Use
      PerXautomatik last edited by
      I'm writing to suggest a refinement for the "GX Corner" tab behavior in Opera GX. While I appreciate the value of the "GX Corner," having it open in every restored window can be disruptive to workflow, especially when managing multiple windows.
      I propose the following improvements:
      Single "GX Corner" instance: Only open the "GX Corner" tab in the currently active window.
      GX Corner as a browser element: Treat the "GX Corner" as a distinct browser element rather than a tab. This would prevent it from being managed as a regular tab, eliminating unnecessary clutter and improving overall user experience.
      By implementing these changes, Opera GX can maintain the visibility and accessibility of the "GX Corner" while minimizing its impact on window management and user workflow.
        S 1 Reply Last reply
        sgunhouse Moderator Volunteer @PerXautomatik last edited by
        @PerXautomatik If you use the setting to put the GX Corner icon in the sidebar, then you can easily have only one (or no) GX Corner tabs showing. Or you can subsequently hide the icon from the sidebar and ignore it completely. Your choice.
