    Problem with sync
    Opera for computers
    2166
      DanielCerqueira last edited by
      I scan the QR code of synchronization, the phone shows the code but the computer is in an infinite loading
        leocg Moderator Volunteer @DanielCerqueira last edited by
        @danielcerqueira You need to login to use Sync.
          D 1 Reply Last reply
          DanielCerqueira @leocg last edited by
          @leocg This is the problem, I'm already logged in
            @danielcerqueira Then that's all, you don't need to scan any QR code.
              DanielCerqueira @leocg last edited by DanielCerqueira
              @leocg It's for me to synchronize with Flow, Speed Dial and Internet History.
              That's when you scan the QR code and then the numbers appear on your phone, to make match with the numbers that appear on the computer, only that in this case the computer is charging and does not appear the numbers.
              is loading infinitely.
              Sometimes it is right, and my flow comes in, but the numbers appear on the phone, and the computer says I'm synchronized, but it doesn't show the numbers on the screen when I get out of the page that shows the numbers on my phone, the computer Stop synchronizing and removes the login.
                leocg Moderator Volunteer @DanielCerqueira last edited by leocg
                @danielcerqueira You said the problem was it Sync, a completely different feature than Flow
                  @leocg You have reason, sorry I got confused, but despite this the problem is close to Sync because when I try to login in the flow and flawed the general synchronization ends.
                  Right now he is saying that he is synchronized my folders, but they are not
