    Url protocol problem on roblox.
    31829
      leocg Moderator Volunteer @Notxsync last edited by
      @notxsync So you are clicking on something in a external app that opens a page in Opera? Or should open at least.
        N 1 Reply Last reply
        Notxsync @leocg last edited by Notxsync
        @leocg i used to i had extensions and stuff for the website, but i disabled all of them.
          Try the test standalone installation as mentioned here.
            Notxsync @burnout426 last edited by
            @burnout426 I did it, fresh browser even though ive tried on every other one. Still says the same thing. "Open URL:ROBLOX PROTOCOL"
            So the problems for sure in my pc.
              burnout426 Volunteer @Notxsync last edited by
              @notxsync We can check your registry keys:
              Install Notepad++. In it, goto settings -> Language and under Tab Settings, make sure "[Default]" has the tab size set to 4 and make sure "Replace by space" is checked. Then, for "registry", make sure "Use default value" is checked.
              Then in Windows, hit Windows key + r to open the run dialog, type regedit and press enter to launch the registry editor.
              Then, right-click on "HKEY_CURRENT_USER\Software\Classes\roblox" in the left-hand pane, choose "export" and save it as roblox.reg.
              Then, right-click on that reg file and choose "Edit with Notepad++". One loaded, hit ctrl + a to select everything, hit the tab key to indent the whole selection by 4 spaces, hit ctrl + c to copy the selection and paste it here in a reply. Then, close the reg file in Notepad++ without saving your changes.
              Then, right-click on "HKEY_CURRENT_USER\Software\Classes\roblox-player" and export it as robloxplayer.reg.
              Then, right-click on "HKEY_CURRENT_USER\Software\Classes\roblox-studio" and export it as robloxstudio.reg.
              Then, right-click on "HKEY_CURRENT_USER\Software\ROBLOX Corporation" and export that as robloxcorp.reg
              Then, do the indentation for those 3 reg files too and paste them here.
              Then in "HKEY_CURRENT_USER\Software\RegisteredApplications", right-click on roblox-player in the right-hand pane, choose "modify", then select and copy the value data and paste it here indented by 4 spaces. Then, click cancel in the modify dialog.
                Notxsync @burnout426 last edited by Notxsync
                @burnout426 I don't understand, what do you mean by indented? I might as well just send the whole file here.
                I don't have enough permission?
                  @notxsync Yeah, if you want to zip up all the reg files, upload the the zip file somewhere and link to the zip file here, that will be fine too.
                  To post code here on the forums, you can indent each line by 4 spaces (add 4 spaces to the beginning of each line). Was just giving you a way to indent all lines in each file at once with Notepad++. If uploading the files and linking to them is easier, that's fine. Whatever what you want.
                    @burnout426 Do you have a work email or a discord i can send this zip to? (preferably discord)
                      @notxsync The email on my about page will do.
                        @burnout426 Sent. Can you fix it for me and send it back? Or will you inspect it to see if anything is wrong?
                          @notxsync Received it. Can you send the exports of the other keys I mentioned too?
                            @burnout426 I sent everything I think.
                              @notxsync Okay. Will get back to you a little bit later.
                                @burnout426 Alright ill be waiting
                                  @notxsync
                                  Could you send these two?:
                                  Right-click on "HKEY_CURRENT_USER\Software\Classes\roblox-player" and export it as robloxplayer.reg.
                                  Right-click on "HKEY_CURRENT_USER\Software\Classes\roblox-studio" and export it as robloxstudio.reg.
                                    burnout426 Volunteer @burnout426 last edited by
                                    @burnout426 And Then, right-click on "HKEY_CURRENT_USER\Software\Classes\roblox" in the left-hand pane, choose "export" and save it as roblox.reg.
                                      @burnout426 ok i sent it.
                                        burnout426 Volunteer @Notxsync last edited by burnout426
                                        @notxsync Got it.
                                        Not sure if you not having "HKEY_CURRENT_USER\Software\Classes\roblox-studio" is a problem or not
                                        It looks like "HKEY_CURRENT_USER\Software\Classes\roblox" is missing the shell, open and command keys.
                                        "HKEY_CURRENT_USER\Software\Classes\roblox-player" looks okay, but I did notice a difference with the command.
                                        I installed Roblox (Windows 11 23H2) by going to https://www.roblox.com/download and choosing "Download Windows app". That installed Roblox just for the current user to "C:\Users\myusername\AppData\Local\Roblox\Versions\version-48a28da848b7420d". In your reg file, I see Roblox is installed for all users to "C:\Program Files (x86)\Roblox\Versions\version-510663c9d33e4fd8".
                                        That should be okay, but that means we should check for HKEY_LOCAL_MACHINE versions of all those keys.
                                        "HKEY_LOCAL_MACHINE\Software\Classes\roblox-player"
                                        "HKEY_LOCAL_MACHINE\Software\Classes\roblox-studio"
                                        "HKEY_LOCAL_MACHINE\Software\Classes\roblox"
                                        "HKEY_LOCAL_MACHINE\Software\RegisteredApplications" (the roblox entry in the right-hand pane for it)
                                        "HKEY_LOCAL_MACHINE\Software\ROBLOX Corporation"
                                        And, look for those same keys under "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node" too.
                                          @burnout426 I sent it but I only sent everything involving Roblox in that node file because I don't know what you can do with that file.
                                            burnout426 2 Replies Last reply
                                            @notxsync In Settings -> Apps -> Default Apps in Windows, scroll down to the bottom and click "Choose defaults by link type", do you see this?:
