    Url protocol problem on roblox.
    31832
      I know you tried:
      start "test" "roblox://test"
      in a command prompt, but what happened when you tried:
      start "test" "roblox-player:test"
      I don't think you explicitly said for that one.
        N 1 Reply Last reply
        Notxsync @burnout426 last edited by
        @burnout426 I don't have the "choose defaults by link type".
          burnout426 2 Replies Last reply
          @burnout426 it says "application not found"
            burnout426 Volunteer @Notxsync last edited by
            @notxsync said in Url protocol problem on roblox.:
            I sent it but I only sent everything involving Roblox
            I didn't see anything that stands out as wrong (as long as "C:\Program Files (x86)\Roblox\Versions\version-48a28da848b7420d\RobloxPlayerBeta.exe" exists).
            With:
            [HKEY_LOCAL_MACHINE\SOFTWARE\RegisteredApplications]
            "roblox-player"="SOFTWARE\\ROBLOX Corporation\\Environments\\roblox-player\\Capabilities"
            , it's technically pointing to "HKEY_LOCAL_MACHINE\SOFTWARE\Roblox Corporation..." and you only have "[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\ROBLOX Corporation", but that should be fine and Windows should translate the path in that case depending on whether you're running a 32-bit or 64-bit version of Roblox (if they even provide both), so that should be okay too.
              @notxsync Okay. So wee need to fix that somehow.
                @notxsync What version of Windows (should have asked before)?
                  @burnout426 Windows 10
                    Scroll all the way down the Default apps page and you might see it.
                      Try a manual uninstall and reinstall like so (ignore any that don't exist):
                      Delete "C:\Program Files (x86)\Roblox".
                      Delete "C:\Program Files\Roblox".
                      Delete "C:\Users\yourusername\AppData\Local\Roblox".
                      Delete "C:\Users\yourusername\AppData\Roaming\Roblox".
                      Delete everything in "C:\Windows\temp".
                      Delete everything in "C:\Users\yourusername\AppData\Local\temp".
                      In the registry, right-click and delete these keys (ignore any that don't exist):
                      "HKEY_CLASSES_ROOT\roblox-player"
                      "HKEY_CLASSES_ROOT\roblox-studio"
                      "HKEY_CLASSES_ROOT\roblox"
                      "HKEY_CURRENT_USER\Software\Classes\roblox-player"
                      "HKEY_CURRENT_USER\Software\Classes\roblox-studio"
                      "HKEY_CURRENT_USER\Software\Classes\roblox"
                      "HKEY_CURRENT_USER\Software\ROBLOX Corporation"
                      "HKEY_LOCAL_MACHINE\Software\Classes\roblox-player"
                      "HKEY_LOCAL_MACHINE\Software\Classes\roblox-studio"
                      "HKEY_LOCAL_MACHINE\Software\Classes\roblox"
                      "HKEY_LOCAL_MACHINE\Software\ROBLOX Corporation"
                      "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Classes\roblox-player"
                      "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Classes\roblox-studio"
                      "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Classes\roblox"
                      "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\ROBLOX Corporation"
                      Delete any Roblox uninstallation subkeys in:
                      "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall"
                      "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall"
                      "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Uninstall"
                      Delte any Roblox entries in the right-hand pane in these keys:
                      "HKEY_CURRENT_USER\Software\RegisteredApplications"
                      "HKEY_LOCAL_MACHINE\SOFTWARE\RegisteredApplications"
                      "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\RegisteredApplications"
                      Delete any Roblox shortcuts on your desktop or ones pinned to your taskbar and ones in:
                      "C:\Users\yourusername\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch"
                      "C:\Users\yourusername\AppData\Roaming\Microsoft\Windows\Start Menu\Programs"
                      "C:\ProgramData\Microsoft\Windows\Start Menu\Programs"
                      "C:\Users\Public\Desktop"
                      Download and install https://setup.rbxcdn.com/version-48a28da848b7420d-RobloxPlayerInstaller.exe (which is what the Roblox site gave me).
                      Restart Windows.
                      Then, do the:
                      test again and try a play button in Opera.
                        N ? 2 Replies Last reply
                        Notxsync @burnout426 last edited by leocg
                        @burnout426 WTFFF Y0 You Fixed It Brooo No Waay I Love Youuuu No Homo
                          @burnout426 Hi,I got the same problem,when i tried test roblox,it show me game client,but when i use roblox.com,it show me url:roblox protocol.
