    Opera Block ads - exceptions problem
    exceptions list
    2296
      I've added this site https://www.journaldemontreal.com on my exceptions list but it stil blocks ads. How do I resolve this?
        leocg D 2 Replies Last reply
        @esky77 Just checked here and disabling the adblocker for the site made the ads to show up again.
          DarthGTB @Guest last edited by
          @esky77 I had a similar problem with the force dark theme on pages exceptions. Try removing all pages from the same domain you may have added to the list and try again. I hope it helps
            Q 1 Reply Last reply
            piris44 Banned last edited by
            I am also facing the same issue. also here for the suggestion.
            • Q
              quoi88 @DarthGTB last edited by
              @darthgtb I've tried that. Still block ads. Any other suggestions?
                D 1 Reply Last reply
                DarthGTB @quoi88 last edited by
                @quoi88 sorry no more ideas. I suggested that in hopes it applies the exception list though the same algo used for the force dark theme exception list. It seems not.
                • Q
                  @darthgtb Thank you. I guess my only option is to leave Opera for other browsers.
                    @quoi88 I'm currently in the moving myself, adapting my workflow, but in case you want to try to stick around, you could theoretically just disable the native ad blocker and install AdGuard or something like that
                    • Q
                      @darthgtb Great, now it's working! Thank you|
