    Opera 95.0.4635.84's Menu Top Right Corner Has Turned Red
    22
    11363
    • I
      Iggyfan @bbildman last edited by
      @bbildman I've been having the same problem. Does the solution still work? If so how do you do it?
        B 1 Reply Last reply
        bbildman @Iggyfan last edited by
        @iggyfan said in Opera 95.0.4635.84's Menu Top Right Corner Has Turned Red:
        Worked for me. Add --disable-update to the shortcut::
        "C:\Opera\launcher.exe" --disable-update
        every now and again the red corner pops up again, and all I do is reload it and it disappears
