    [Duplicated]Flow not working
      stewarth 0 last edited by
      Cannot keep Flow connected to my PC. It's ok phone and tablet.
      This new Opera One has messed it up. Also I keep having to log in and sync data. Can I go back a version until it's sorted?
      Reply Quote 3
        Silm4ril last edited by
        Same here 😕 Unfortunately, noone seems to be able to help.
          PanicPug last edited by
          Same here
            Just tried and was able tio connect using Opera Developer 101 and Opera for Android Beta 76.
              S 1 Reply Last reply
              stewarth 0 @leocg last edited by
              @leocg
              Interesting. I have no problem with Flow between my phone and tablet. But on the PC I have to login to Flow
              scanning the QR code with my phone, it connects.... then my phone wants confirmation by following instructions on the PC.....there are no instructions on the PC!
              The Flow is connected and usable for some seconds then it times out and kicks me out of my Opera connection and I have to go through the whole log in to Opera and set up sync all over again.
              I've deleted Opera 1 and installed the previous version, but....guess what.....when you restart Opera back comes Opera 1 !!
              The silence for the Opera people is deafening!!!!!!
                Yes, exactly that. Between the Android Browsers Flow works and synchronisation in general as well, but between PC and Android it's exactly as you describe.
                I got it to work for now: after scanning the QR code and leaving it at the "follow the instructions on your device" (or something along those lines) then closing the opera app in Android's recent apps overview. When starting the app again, flow was working.
                But on top of that the synchronisation between multiple PCs seems to be screwed as well. I especially notice it in the synchronised tabs: whereas each of my android devices is shown once in the tabs/devices list (as it should be) each PC shows up multiple times. At the moment some of them seem to show up around 20 times with different tabs each 🤓
