    I'm having a login problem
    Feedback for the Forums
      phillipinaepicgamer last edited by
      Hello!
      I am having problems with loging in.
      The only way I can log in is via a google account.
      If I try using email, pressing "create account" won't work.
      The only thing it will say is "copy" when I double click on the link.
      Please fix this problem.
      Thanks!
        leocg Moderator Volunteer @phillipinaepicgamer last edited by
        @phillipinaepicgamer So you can't login or you can't create an account?
        Can you login at https://auth.opera.com/account/login? What about creating an account?
          P 1 Reply Last reply
          phillipinaepicgamer @leocg last edited by
          @leocg I can't login or make a new account on the website, however I can for some reason do it on the forums by pressing "login to reply".
            @phillipinaepicgamer That is the page to login to your Opera account, when you click on Login in the forum, you are redirected to that page.
            Kinda strange that you can't login when you open the page directly.
            Can you login to other Opera services, like www.sync.opera.com, for example?
