    [Duplicated]ffmpeg video decoder problem
    8775
      kinodegna last edited by kinodegna
      @burnout426 it has happened after upgrading Windows 7 to Windows 10 with Media Creation Tool
      I have created new Windows account, installed and tested on all 4 versions just after installation and had same problem on every of them. Didn't try Vivaldi there because it was first time I ever installed it.
      And yes, it happens on video-only mp4 files. But if I create audio-only mp4 it plays fine
      Also tried all fixes from Codec Tweak Tool > General > Fixes (including Reset Media Foundation). Even after system reboot nothing changes for the problem.
        burnout426 Volunteer @kinodegna last edited by
        @kinodegna said in [Duplicated]ffmpeg video decoder problem:
        Hmm, there could be something to that. I guess you could check your system files.
        Installing Windows 10 from scratch (no upgrade) has a high probability of fixing it (unless it has something to do with the Enterprise version of Windows).
          K 1 Reply Last reply
          kinodegna @burnout426 last edited by
          @burnout426 already tried both dism and sfc. All system files are OK. It was my first idea.
          And of course installing Windows from scratch will help. But I have no option to do it now.
            What is a difference between decoding h264 in Chrome/Edge (where is no issue) and Opera/Vivaldi?
              leocg Moderator Volunteer @kinodegna last edited by
              @kinodegna Chrome/Edge has the license to use the h264 codec and don't depend on the OS for it like Opera and Vivaldi.
                In Windows, at "Settings -> Apps -> Optional Features -> More Windows Features" (optionalfeatures.exe), instead of just checking if Windows Media Player is enabled under "Media Features", try removing Windows Media Player and then adding it back in.
                I'm surprised that h.264 works in Windows Media Player but not in Opera. Under "Legacy Components", do you happen to have "Direct Play" enabled? It's not enabled here.
                  Are you running Opera and Vivaldi directly or via something like Sandboxie?
                  Any security software (anti-virus or other) that you're able to disable temporarily to see if it's interfering for some weird reason?
                    @burnout426 only ESET NOD32 Antivirus. I've just removed it (and its services) from windows startup and re-tested. The problem is still present.
                      kinodegna @burnout426 last edited by kinodegna
                      @burnout426 said in [Duplicated]ffmpeg video decoder problem:
                      Direct Play
                      What is it? How can check if it enabled?
                      I've removed WMP, check that it was actually removed after rebooting, then added the component back and rebooted again. WMP still plays h264 and Opera still can't.
                      Also, as I remember, the only thing that I have been asked to remove to continue updating Windows 7 to Windows 10 was Windows Media Player. But after update it was already installed.
                        kinodegna @kinodegna last edited by kinodegna
                        Found Legacy Components in optionalfeatures.exe. It's not checked and child "Direct Play" also not checked.
                        I've enabled it and rebooted - no changes, disabled and rebooted - still no changes.
                          "Direct Play"
                          It's the old way of providing codecs for Windows. It won't have any effect on Opera and Vivaldi, but I was wondering if that's how h.264 was still working in Windows Media Player.
                            You've basically tried everything you can. But, I'll let you know if I have any other ideas to try. Maybe it'll fix itself with the next major Windows update that comes out. Might be a bit though.
                              Is there is a way to find what dlls (or other system files) my Opera tries to use for h264 decoding?
                                @kinodegna Not sure, but https://learn.microsoft.com/en-us/windows/win32/medfound/h-264-video-decoder lists Msmpeg2vdec.dll, which is in "C:\Windows\system32" for me.
                                I have file version 10.0.22621.1105 on Windows 11 Version 22H2 (Build 22621.1105) 64-bit.
                                  Anawilliam Banned @burnout426 last edited by
                                  @burnout426 thanks, I have a similar problem, I will try this
