    General my/a site is not working topic
    Opera for computers
    34
    59
    39534
      pasoorii last edited by
      I'll very thankful to you.
      panoramacharter.ltd
      19216811.bid
        Hi,
        I just check my website https://nerfweb.com/ speed on the Google, it's 90 plus both for the mobile and PC. The website was also working fine on the Opera. But as soon as I updated Opera on the laptop. It taking too much time for opening any article. 😞 Can I recover my old version of Opera?
        I love Opera Brower for my regular working. I don't know why it's happening with me! Can you please guide me in this regard. Thank you
          Pappis last edited by
          Hi,
          Since recent updates - I think to version 92 - some websites have stopped working in Opera:
          • yle.fi (the Finnish national broadcasting corporation)
          • zinio.com (major emagazine site)
          The site yle.fi does not work at all. Opera does not anymore open the site at all. I can still load and see the site zinio.com correctly, but I can not login. Opera opens the login prompt, but clicking the login button does nothing.
          My PC is an up-to-date Win10 Pro 21H1. Fully clearing Opera cache had no effect to the issue. Other Chromium browsers (Edge, Chrome) work correctly with these sites. Disabling my only add-on Ghostery and/or my PC's AV software has no effect to the issue.
          Any suggestions?
            @amiloab
            Can you please check, I'm facing the same issue with this too https://nerfweb.com/best-nerf-rival-gun/
              @amiloab Site loads fine for me in the USA, FWIW.
                @burnout426
                Thank you for the confirmation, I think I need to update or removed cookies.
                  Hi, I created a website a few months ago by using WordPress and install premium theme on it but now i am facing a problem that one of my website's page https://alightmotionapps.com/alight-motion-pro-apk/ is not responsive on opera search engine. please suggest me solution of this problem
                    Kumar82 last edited by
                    Hello, The Crickist website is working OK in Chrome and Edge. However, I am experiencing a network issue. This website does not support Opera VPN, which I want to use. Facebook, MSN, and Google all function properly; I've tested them all. Please provide help. Thanks
                      leocg Moderator Volunteer @Kumar82 last edited by
                      @kumar82 If the site blocks VPNs, I guess the only way is to access it without using the VPN. Or you can try using another one.
                        emanfatima0786666 last edited by
                        I want to open a website  comprarseguidoresig  but there some error show. If anyone help me to please give me the solution.
                          HI there fellows, I have been using opera since I started using internet. I have a food blog which I speed optimized using wp rocket and optimizing images in WordPress. It is having loading speed issues in Opera and Firefox. I checked the speed with Gtmetrix and its around 1.5 seconds. Is it the lazy loading causing the issue if yes then why chrome is loading fine.
                          I am confused.
                            Hey! Hope all are doing well.
                            I have a website which was working very well, recently i got notified by one of my friend that my site is not showing proper layout stucture on opera browser, i have also checked it on other browsers like safari, chorme, mozila firefox, etc there it was showing great results, i have checked it many times but could not found any solution for my site.
                            Can anyone please guide me whats wrong with it. Site is Proptinomanager
                            Waiting for Response, Humble Regards,
                            Milly
                            Thanks
                              @millycirs112 All extensions are disabled as well as ad and tracking blockers?
                                A Former User @leo133 last edited by
                                @leo133
                                There are many sites that are facing the same issues on the opera, when I was trying to open this random site https://paintballingpro.com/ there was the same issue. So, after uninstalling this recently updated version it was working fine. I just checked your site https://4lolipop.com/ on my browsers now it's working good.
                                  Hi there, I have a question regarding my website, which is a tool-based website called cps-tester. It seems to be functioning well on all search engines except for Opera. I'm concerned about this because my target audience predominantly uses Opera instead of Google. Could you please assist me in resolving this issue? Many pages of my website seem to be lagging in the Opera browser. Thank you in advance for your help.
                                    @georgebush15 What would be the problem with the site?
                                      victorgreen449 Banned last edited by
                                      Hello, I'm having issues with opening my website on Opera Windows. I open my website login panel inside Opera and it starts loading and loading but at the end page shows as broken page even I cleared cache and restarted browser but it's still the same. On other hand I'm my using my site in other browsers it works fine (even other sites i opened in Opera all are broken and keep loading). How can i fix it? Thanks
                                        V ? 2 Replies Last reply
                                        victorgreen449 Banned @victorgreen449 last edited by This post is deleted!
                                          A Former User @victorgreen449 last edited by This post is deleted!
                                            i have been trying to login on few website like
                                            and web site it not showing website the full page do i need t restart my opera
