    [Solved]How fix tiny icon in speed dial?
    solved
      The icons you see are favicon. How fix tiny icon in speed dial? I couldn't find it in Opera settings.
      alt metni
        @iautr Try downloading the offline installer and run it.
          @leocg It will probably be fix as you say. I was hoping to fix it without deleting it. Thanks for your help. I'll report back if it's fixed or not.
            @iautr Deleting what? Nothing will be deleted.
              @leocg I am so happy. I installed without deleting. My problem is solved.
              • Referenced by
