    speed dial thumbnails are smaller?
    25
    14119
      There's a new build at https://ftp.opera.com/pub/opera/desktop/86.0.4363.50/win/ for Opera Stable. You should be able to check for updates eventually (edit: mine just detected the update) and Opera should fetch it and update. Until then, you can download the installer (make sure to get the x64 one if you're using 64-bit Opera now), launch it, click "options", set "install path" to your current Opera install folder so that the installer says "upgrade", adjust the other options as you want, and upgrade. That should hopefully fix it.
        B C 3 Replies Last reply
        bschoofs @burnout426 last edited by
        @burnout426 sounds good. After my last apointment i'll give that a go.
          bschoofs @burnout426 last edited by leocg
          @burnout426 Oh yeah. 86.0.4363.50 got installed and Bam it's all back to normal
          • Z
            zauberfritz @darkskys last edited by zauberfritz
            @darkskys There is some reset, but on my screen they are (overwhelmingly) larger than before. But maybe I changed my settings after the initial shrinkage and mutilation.
            Edit: yes, I did, there's an option 'larger tiles'. Unchecked it, and it's back to ' normal'. 😉
            Reply Quote 3
              CTH @burnout426 last edited by
              @burnout426 Thanks a lot. Opera was updated to the latest version for me (86.0.4363.50) and the tiles were still broken, so based on that, the auto-updater may have some problems. After reinstalling using the setup file everything's fixed. 😃
