    [Solved] Opera doesn't allow selected popups to fully display data entry options
    solved
    • W
      wnorthland last edited by leocg
      One of the websites I frequent has an online database for saving information. This function was working fine up until recently, but suddenly stopped working. When I select a specific popup to add data, the popup starts but only displays the title - the data entry lines don't show below the title line. Normally, there will be a secondary activation that brings up the data entry lines. One additional feature is also not working but is difficult to describe - the two features are related to the same database. I've tried every setting I can think of, but nothing seems to help?
        leocg Moderator Volunteer @wnorthland last edited by
        @wnorthland See https://forums.opera.com/topic/43601/instructions-on-posting-about-problems-in-opera-for-windows/1
          W 1 Reply Last reply
        • W
          wnorthland @leocg last edited by
          @leocg
          Sorry, missed the instructions.
          It turns out that it was a browser extension that was causing the problems. Not sure why, as everything worked fine up until recently. Regardless, it is nice to have this resolved.
          Always learning,
          wnorthland
