    Flow, connecting to PC
    Opera for Android
      Larca91 last edited by
      Hello,
      can someone help with with connecting flow with PC? I use Opera for android on my phone, I am logged in, syncing is on, but every time I want to connect a flow with QR code, it fails. Wen I click on other options and then to login, well, it logs, but that's it.
      Have anyone found a solution?
      A while ago I was successfully connected to Opera Touch. But Since I thought than maybe only one app can be connected, and I wanted it to be Opera for Android, I disconnected. And now I cannot connect with any app.
        leocg Moderator Volunteer @Larca91 last edited by
        @larca91 How are you trying to connect? Are you opening www.opera.com/connect on computer and scanning the QR code from there?
          L 1 Reply Last reply
          Larca91 @leocg last edited by
          @leocg yes. Also by trying to scan a QR code that flow on browser provides (Opera Flow has those instructions). It doesn't connect, bo matter which QR code I use or with which app I try to connect.
