    Out Going Mail Problem
      pixations last edited by
      I'm using Opera for some of my Pop mail accounts,
      but I'm having trouble with Outgoing mail. My
      emails are still sitting in the outgoing folder,
      I'm not sure where my setting are wrong. I've
      tried looking but I haven't found any help in
      any readme documents or help areas. Can someone
      point me in the right direction,, post a link,,?
      etc.
      Thanks,
      Ron
        If you try to send them manually (by clicking on "send queued"), are they sent?
        Try also rechecking your smtp settings, including username and password.
          I'm not seeing anything shown as "sent", that folder is empty.
          Everything in smtp looks okay, I double checked the user name
          and password. The port is #25, and Authentication set to Auto.
          I have mail coming in,, but nothing going out. It's affecting
          3 accounts I have set up there.
          Ron
            Try changing the port to 465 or 587.
              I had the same problem. Changing ports solved the problem. I used port 465.
