    QR Code & Login Problem
    Opera for Android
    4439
      When I want to login by scanning qr, it waits for a long time in the browser. After waiting, it says "connected" on the computer, while it says "not connected" on the phone.
        Additional
        When i want to login with username and password, i log in at first. It logs out after 2 seconds and asks me to re-enter the password. When I enter the password again, it says the password is incorrect.
          @bakinazik Did you recently change your Opera account password?
            @leocg Yes, i did.
              @bakinazik Then try using the old password if Sync says it's wrong.
                @leocg It's unlikely that I will do this because I keep my passwords in the password manager. I can't remember the old password. Exactly how many days does it take for both systems to become compatible with each other?
                  @bakinazik What systems?
                    @leocg as far as i see there are two systems that are not synchronized with each other at the same time
                      @bakinazik But what two systems? The one with QR Code and the other with the login?
                        @leocg I still can't login with qr code..
                          I see the message that you are connected through the computer, but the device gives a "rejected" warning from the phone.
                            the problem still continues...
