    How to get flow working with Opera for Android
    Opera for Android
      lancealot last edited by
      I have my Opera desktop setup to sync with a passphrase. The sync works fine on my opera desktop and opera for android. The problem is I can't get flow to connect. When I click Flow in opera desktop and then "Connect to Phone" it shows the QR code. In opera for android I go to Flow in the settings, and then click "Connect Device" and scan the QR code. It always says "Pairing - The use Flow, you need to set up syncing between your device. Navigate to opera.com/connect on your other device". The problem is I got syncing setup and working between the devices. If I use "Other Options" and use "Sign In", that also doesn't work.
      The only way I was able to get it to work on opera for android is using the quick setup option for flow which creates a random account to use for all opera sync operations. I want to use my existing sync account with flow. Is this even possible?
        ? 2 Replies Last reply
        A Former User @lancealot last edited by
        @lancealot bro I have the same problem 😞☹
          A Former User @lancealot last edited by This post is deleted!
            Hi! I installed the Opera beta app (but I also tried with Opera and Opera Touch). Account syncing is successful, but My Flow connection fails (connection refused on other device). The phone has Android Flyme 6.0.2.3G and the Opera Beta version is 62.0.3146.5700. On the PC I have Opera 74.0.3911.107.
            I hope to have information thanks
