    [Solved] Speed dial icons not matching website
    Opera for Mac
    solved
      I've seen similar issues posted but nothing exactly and nothing that resolves my issue... if there is a post(s) that can help please direct me to them... thanks in advance!
      On the website, click the heart icon to select the icon...
      On the speed dial page it does not display the icon, just the text...
      I've deleted and recreated the bookmark, I've changed the icon multiple times and it always just shows the text on the speed dial page.
        @gh0brien The image shows that you are bookmarking the page at Other Bookmarks. If you bookmark it in Speed Dial, can you see the correct thumbnail?
          @leocg said in Speed dial icons not matching website:
          Aha! Apparently I had 2 separate bookmarks and was editing the wrong one... just starting using Speed Dial so on a learning curve.
          Thank you 🙂
