    How to change default language for Wiki search engine
      I want it to be in English, and not my native language. But, there isn't an option to change built in searches. Is there any way to do this, without creating separate Wiki search for english?
        leocg ? 2 Replies Last reply
        @corey There isn't a way to change it as far as I know.
          @leocg said in How to change default language for Wiki search engine:
          From where does Opera pull information about my location? I never use Google in my native language, and don't want to.
            @corey Probably from your system, don't know for sure.
              @corey It can not be change as I have also tried doing it but got failed.
              • xantares
                xantares last edited by
                As you say there is no configuration option to select the language version built-in Wikipedia search uses.
                As @leocg suspects, Opera probably uses system locale to determine the Wikipedia language version: Neither Opera UI-language nor language preferences (→ Accept-Language: .. HTTP header) influence the Wiki search language, experiments prove.
                I can suggest my Xeno Wikipedia (addons.opera, chrome web store, …) extension, though, which allows you to set an arbitrary default while being flexible to allow you to request other language versions occasionally. Maybe it suits your needs.
