    [Solved]Theme between light and dark
    solved answered
    3309
      Is there a theme I can use that is in between the dark and light theme, with the latest Opera version, using Win7?
        @ashley29er There isn't.
          @leocg I really wish there was! Heavy on the eyes - I unfortunately don't like the dark mode!
          Thanks
            @ashley29er You can suggest it on the proper forum.
              @leocg You aren't being very helpful. I thought this was the right forum!
              I definitely wouldn't call my problem " solved"
                leocg 2 Replies Last reply
                @ashley29er The Suggestions and Feature Requests forum, under the Opera for Computers one, would be the right place for it.
                  @ashley29er You made a question and it was answered. Topic is solved.
