    [solved]Annoying sound on page load
      ethv last edited by leocg
      Hi. I'm using latest Opera on Windows (66.0.3515.95) and I get a very annoying sound when pages gets loaded. Not on all websites but on about half of them. I found no setting for disabling that and it only happens on my work PC.
      How can I disable that?
        leocg Moderator Volunteer @ethv last edited by
        @ethv As far as I know, Opera doesn't have such sounds. So they are probably coming from the sites or from an extension.
        Aren't you using Opera GX by chance, are you?
          ethv last edited by ethv
          You are right, it was coming from my "Autofill" extension... (Play sound effects after every autofill operation.)
          Thank you!
