    [Solved]"Hide Speed Dial" isn't kept between sessions
      When I close/restart Opera, I have to go into settings and turn off the "Hide Speed Dial" selector. Is there a "Save" button I'm overlooking?
      Windows 10
      Version is 62.0.3331.109 (Opera is up to date, Last checked on Friday, August 23, 2019 09:30)
        @preston-brooks What about Opera 63?
          ? 2 Replies Last reply
          @leocg Sounds agreeable to me. I guess I don't understand Opera's updating and versioning processes. When I check, via the browser, it says my version is up-to-date and gives the version number. This morning I received notification that version 62.0.3331.116 was ready to install (via Iobit Uninstaller 8.6 app). Those are the inputs into my understanding of the current version of Opera. How would I have know to look for Opera 63, had you not mentioned it? Bear in mind I'm just a casual user. Thanks.
            @leocg Update. I went to the Opera site to see see about downloading version 63. It didn't specify which version was available, just presented a "download now' button. Turned out to be version 63.0.3368.43. This version actually fixed 2 problems I've been having: (1) the speed dial section, when it wasn't hidden, would be so far below the google search bar that I had to scroll down to find them and (2) the problem of the speed dials not being kept between sessions. Both are fixed. Thanks.
