    site blocking problem
    3113
      for a reason incomprehensible to me suddenly a website, very important for me, despite the green padlock on the address line.
      Could you tell me how I can correct the situation?
        @relativamente The situation would be....?
          @leocg said in site blocking problem:
          would be that the site does not open ... the address appears, the logo but the pages remain white.
          Point out that the same site on google opens without problems
            @relativamente Does it open in a private window?
              not in a very normal context, in the middle of other 5 windows that normally work this, despite all the changes made by acting on the green padlock nothing appears.
              I almost feel like something is blocking it like a dangerous site
                @relativamente Adblocker is enabled? If so, did you try to disable it for that page?
                  no Adblocker is not active
                    @relativamente What is the page?
                      What is the page?
                      the page is https://www.wish.com
                        @relativamente It's loading fine here.
                        Do you use any extensions? If so, try with them disabled.
                        Try also cleaning cookies and cache.
                          I don't know what you mean by extensions, then which disabling do you refer to?
                          Do you suggest cleaning the cookies and the cache, but this will compromise the other pages I use all the time?
                            @relativamente If you don't know what an extension is, then you problem don't have any installed.
                            You can clean cookies just for a specific site.
                              How do I clean the cookies for the specific site?
                              I have seen on settings, only the instruction for cleaning cookies in a generic way and I fear total cleaning
                                @relativamente Go to settings page and search for cookies. Then click on site settings.
