    Taskbat Pin doesn't work
    32
    17165
    • crolug
      crolug @Guest last edited by
      @tparavani Yeah, it works, thanks! At least we have a workaround for now. I just do hope they will fix it soon.
        @tparavani yes! that worked! thank you! 🙂
          This bug still happening on version LVL 1 (core: 60.0.3255.50962). I tried reinstaling but it doesen't fix it.
            rommie last edited by
            Hello, I have such a problem that I can not attach to the taskbar the two icons of different Opera and Opera GX browsers.
            The film that I recorded shows the problem most:
            https://www.youtube.com/watch?v=h9YbzLHpOkg&feature=youtu.be
            How to make these icons not disappear after starting the program?
            Sorry for my english. 😢
              Merging similar topics
                nutricionistajorgeferreira last edited by
                I update the opera GX to the LVL 1 (core: 60.0.3255.50962) and the problem stays there
                  leocg Moderator Volunteer @leocg last edited by This post is deleted!
                    @tparavani it worked thanks i was this close to delete it until it was fix ,it was not a big deal just annoying
                      breat last edited by
                      I have the same problem, but I found a solution to fix it :
                      1°) Go to the installation folder of Opera GX
                      2°) Right click on "launcher.exe" => send to => Desktop (shortcut)
                      3°) Move the new shortcut in the installation folder of Opera GX
                      4°) Rename the shortcut "Opera GX" for more visibility
                      5°) Drag the new shortcut from the installation folder of Opera GX to the taskbar and unpin the Opera (classic if is already pin
                      6°) Enjoy!
                      PS : sorry for my english
                      https://breat.fr
                        Hi there, I am having the same problem and I have installed using the "All Users" option. For me I noticed that if I pin it then close the browser it stays pinned. If I open the browser again and close it it unpins itself.
                          I want add opera to the Windows taskbar, i add it but every time i open Opera the icon is removed from Taskbar when i close it. Why and how to solve?
                          Steps:
                          • right click on the opera desktop icon
                          • add to taskbar
                          • open Opera
                          • close opera
                            Results: the icon is no more present on the Windows taskbar
                          La tua versione è LVL 1 (core: 60.0.3255.50962)
                            after the icon on the taskbar missing every time i was opening it from there ,we solve that ok
                            now i guess after the last update, i have it in the taskbar but it cant be deleted shortcut from windows home screen
