    I need one speed dial for all devices .. How?
    Synchronization
    sync syncronization speed dial
      khaledbelal last edited by
        leocg Moderator Volunteer @khaledbelal last edited by
        @khaledbelal Not possible as far as I know.
        Reply Quote -1
          zalex108 last edited by
          On desktops you can try this - just tested on Windows.
            K 1 Reply Last reply
            khaledbelal @zalex108 last edited by
            @zalex108 Can't me do it by Opera Sync in version 54 (last version now)?
              The default Opera behaviour is to use different SD on each device.
              As far as I know, you will need to do those steps.
              Also,
              creating a default custom profile, will save you lots of time.
