    Speed Dial and bookmarks not consistent.
    2119
      bookmark
      https://www.reddit.com/r/all/
      goes to
      Good!
      Speeddial
      goes to
      https://www.reddit.com/?utm_source=Opera_Browser_For_Computers&utm_medium=SpeedDial&utm_campaign=Outside_folder_placement
      which redirects to
      Bad!
      change in url handling only happened in the last few days.
        @mattheww How did you add the Speed Dial entry?
          @leocg
          Hi Leo, Thanks for getting back.
          Added the entry using 'add a site' button some time ago.
          I have just made a new one and it works as intended so I now have 2 , both with the exact same URL in the address dialog . The new one works, the old one still doesn't.
          Odd.
          Anyhoo I guess this is fixed.
          THX
            @mattheww And did you type the page address to add it or did you pick a suggestion and added it?
              @leocg
              cut & paste from the address bar
                @mattheww And what was the address? It was only https://www.reddit.com/r/all/?
                  @leocg
                  yes. and it worked correctly until a few days ago.
                  I've deleted that speeddial entry now in favour of the new one which works.
