    Problem with a web page when clicking on an article
    solved
    3006
      I have msn.com as my home page. This displays fine, but when I click on one of the articles, the new page displays correctly for a few seconds, but will then mess up the whole display. Text moved to very small fonts and lined up on the left side of the page. The article info is viewable if I page down, but text is very small. I can go to other web sties and view other pages and they display normally.
        @val0194 Is the ad-blocker on? If so, did you check with it disabled for that site?
        What about extensions?
          @leocg I do have ad-blocking on - that causes this? I don't have any extensions - no idea what kind I would need.
            leocg zalex108 2 Replies Last reply
            @val0194 yep, ad-blocker may cause such issues. Try testing with it disabled.
              @val0194
              Didn't tested but, FanBoy list maybe skips those problems.
                @leocg I turned it off and it so far appears to have fixed the issue. Thx!
                  @val0194 Good to hear that it's fixed.
