    Dropbox block problems
      theodor56 last edited by theodor56
      When trying to open a textfile in Dropbox online, a window opens that says:
      "word-edit.officeapps.live.com har blockerats"
      so the file can not be opened.
      Requests to the server have been blocked by an add-on. Try disabling add-ons."
      I have no idea where I can do this? Someone who knows?
        zalex108 last edited by
        Toggle blue the shield on the Address bar or look at How to report problems in Opera steps.
        For the clean profile:
        • Opera Help > Find solutions.
          | - And rename the profile folder -.
          leocg Moderator Volunteer @theodor56 last edited by
          @theodor56 Did you try disabling the ad-blocker?
            T 2 Replies Last reply
            theodor56 @leocg last edited by
            @leocg
            Yes I did, but after reloading dropbox there was no difference.
            The same message came up on the screen.
              @leocg
              Some more basics:
              WIndows 10 64
              Opera version 49.0.2725.47
              The problem is that when trying to open a wordfile in my dropbox I get the following message;
              "word-view.officeapps.live.com har blockerats
              Förfrågningar till servern har blockerats av ett tillägg.
              Testa att inaktivera tilläggen."
              When using Microsoft Edge or Chrome there is no problem, it works as it should, but not in Opera!!
                It seems that the problem may be with Word online and not with Dropbox.
