    What happened with Speed Dial thumbnails?
    18143
      They're gone forever or?
      For example, some speed dial suggestions have thumbnails, and when I add them, they're present. But every speed dial item I added manually, doesn't have thumbnail. Can this be changed?
        leocg ? 2 Replies Last reply
        Try a F5 in SpeedDial.
        If not fixes the problem, try with How to report problems in Opera steps.
        For the clean profile:
        • Opera Help > Find solutions.
          | - And rename the profile folder -.
        • You can try renaming BookmarksExtras before.
          @zalex108 said in What happened with Speed Dial thumbnails?:
          F5 didn't fix problem.
          I reinstalled Opera prior to posting this, trying to fix this. So I started with clean profile.
          What BookmarksExtras file is for exactly?
            zalex108 leocg 2 Replies Last reply
            @corey said in What happened with Speed Dial thumbnails?:
            Not that I know.
              Why did they remove thumbnails....
                Works then?
                Follow the told steps.
                  @corey they did?
                    Works then?
                    No, it didn't work.
                    I need to know what that file is, so I can fully restore my bookmarks in new installation, and leave out speed dial only.
                      @corey
                      Reading the told steps "Help" you'll find the answer for that file and many others.
                        @corey
                        Okay.
                        Looking at that page right now, but didn't find what are these files for, that are next to regular Bookmarks file:
                        Bookmarks_000
                        Bookmarks_001
                          @corey
                          Followed every step. Still no thumbnails, besides deffault ones that come with Opera (Facebook, YouTube, Bookings...). Every bookmark I add to speed dial is without thumbnail.
                            @corey It contains the bookmarks thumbnails if I remember correctly.
                              @corey Speed Dial is part of bookmarks.
                                @leocg
                                Can anyone confirm me that they have thumbnails working at all? As far as I can see, this feature is not present in Opera, besides some big websites, like Facebook, YouTube, Booking...
                                  B leocg 2 Replies Last reply
                                  bbildman @Guest last edited by
                                  @corey
                                  Absolutely. I have 2 laptops, Windows 7 and the Speed Dials that have been there for many of the last iterations of Opera are still ever present
                                    It seems that it was a misunderstanding.
                                    If you mean default Opera thumbnails alike, then it depends on the website.
                                    The most "similar" is, adding a bookmark, click on the left arrow to select the "default" thumbnail.
                                    It would appear the default Logo or the site or the Domain name.
                                    Is this what are you referring to?
                                    This are the "default" thumbnails on my SD.
                                      @corey Some sites have partnership with Opera, I guess, and there logos will appear as thumbnail when you add them to Speed Dial/Bookmarks.
                                      For other sites Opera will use the site address schema. You can however, change the image later if you want.
                                        Where is this left arrow?
                                        So, I was correct the whole time, Opera did remove thumbnails (logo or website thumbnail, like mini preview).
                                          zalex108 1 Reply Last reply
                                          @corey
                                          Minipreview...
                                          You are referring to the Old Opera - I suppose -.
                                          Those thumbnails are no longer available.
                                          The left arrow:
                                          Default thumbnail using left arrow
                                            @corey I am in Opera 51. There is a workaround, but is for more advance users.
                                            Look into \AppData\Roaming\Opera Software\Opera Stable\Bookmarks
                                            Edit the file and point the link to the image. Hassle. But can't help.
