    [Solved]Speed Dial not Synching
    • G
      grafromtheshire last edited by
      Hi
      I have a work laptop and home PC both using Opera 47. My understanding is that the speed dials should be the same between both windows devices. But they aren't. I can see my work laptop speed dials in a folder 'bookmarks/other speed dials' on my home PC but can't see a way to get them set up.
      Can anyone help pls?
      Thanks
        leocg Moderator Volunteer last edited by admin
        See [Sync]Frequently Asked Questions
        You can copy the entries to the 'Speed Dial'folder.
        • G
          So I can! Thanks very much
