    Problems with copy/search-function when marking text
    1714
      chriscringle last edited by
      When marking text it automatically comes up the "copy" and "search" option, but when clicking this nothing happens. This used to work many months back, but no longer.
        zalex108 last edited by
        Take a look at Settings:
        <img src="https://farm5.staticflickr.com/4211/35422529066_d8da8e21da_o.png"
        If enabled, try in a Private window
        Test profile | Back up Linux · Mac · Win
          Check with Opera 46, released today.
            Works in private mode....what't the problem, then? I also have the latest release.
              This usually means that a extension is causing the issue. It can also be a broken profile folder.
                Ok, how can I fix a broken profile-folder? 🙂
                  Rename it so Opera will create a new one.
                    Thanks, Leocg 🙂
