    Misc problems with Opera 20
      roedy last edited by
      Is there anything that can be done about the following problems with Opera 20?
      It sometimes refuses to load documents from local hard disk.
      It will not let you configure your own editor to replace view source.
      It makes you click every instance of every Java Applet before you view it.
      It thinks Java Web Start is not installed.
      It sometimes gets the vertical positioning of text wrong.
        many complaints regarding java and flash players reported by user when visiting my blog http://vidzonline.com in opera and internet explorer.
          Afaik, it's not possible atm.
          If you mean that you need to click on a "play button" for the aaplet to run, then you need to disable off-road mode (or turbo) and/or "click to play 9or plugins on demand)".
          Do you have Java installed?
          Any kind of doccuments?
