    Unsorted Bookmarks hidden and Help page is in Japanese
    8400
      My Unsorted Bookmarks are now hidden , its a pain , and this sucks , i don't like this change , FIX IT back to where it was before , also when i go to the Help page its all in Japanese , so i can't even access help , it was a pain just to get to here , this needs to be fixed TODAY !!
      QUESTIONS:
      How do i go back to the prior version ??
      When is this ISSUE (yes this is a Issue !)going to be FIXED and put back to the way it was ?? , hopefully NOW !!!
      This version just ruined Opera for me , if its not going to be fixed i am uninstalling Opera , thanks for making changes without asking for our input , Not Happy .... Version 43 SUCKS ! , having to search for things makes this as useless as Internet Explorer , Opera was fine the way it was , the changes made were unnecessary and made this browser a pain to use , i now have to do 3 steps that prior only took 1 , PUT IT BACK THE WAY IT WAS PLEASE !!!!!
        Also all Foums i visit (crfsonly.com , vitalmx.com , etc all look like text now , what did you guy do ??? you screwed everything up , i am going back to firefox till you fix this crap...not happy....
        • shelluser
          shelluser last edited by
          Have to agree about the unsorted folder, that used to be very handy to get to sites without too much clicking. An alternative can be the bookmark bar though. Place all those "unsorted bookmarks" in there, and then simply press control-b to show them and control-b to hide them again. I think could end up even better than relying on the Opera menu.
          How do you access said help page, by pressing F1? Opera doesn't have build-in help but relies on the Opera website. So if that now ends up in Japanese then I can't help wonder about your language settings.
          Go to your Opera settings (alt-p), open the browser section and then check what it says under 'Languages'. Both the user interface, but mostly the Preferred languages.
          QUESTIONS:
          There is no default way to revert back. You could try using Windows' own "recent versions" feature. So go to AppData\Roaming\Opera Software, right click on 'Opera Stable' and check for previous versions. That might help. But only for so long, because Opera automatically upgrades itself to later versions.
          I have to agree that "continuous update" model has its flaws. However, there are usually ways to work around it.
          Sounds like a plugin going haywire, I'm not sure. What happens if you open private mode and then visit those sites? So when in Opera use: control-shift-n. Then re-visit, does that change anything?
            'Unsorted bookmarks' is being removed. If you didn't have anything on it, you no longer will see it.
            How do you went to the help page? Here I'm being lead to a page in English.
            Un-install the current one making sure to leave your data untouched and install the version you want. You will need to do it offline and rename the auto-updater executable file ater the installation to avoid Opera to upgrade to the most recent build.
            Both look fine here. Try checking with extensions disabled.
              The issue is , I DO use the Unsorted Bookmarks and i have lots of them in there , so it SHOULD have stayed , the issue with the websites , is I DID NOT CHANGE ANYTHING !! , this CRAPPY UPDATE DID !!! , i have seen several posts about people with the same issues , WHY IS THIS NOT BEING FIXED ??? , i am beyond pissed ,all i did was click on it and it was working fine , then the next time it was this crap .....The Update SUCKS , Period , it needs to be put back the way it was , why does everyone have to mess with stuff that worked fine , then they completely screw it up ???
              If you go to the Menu , it says near the bottom HELP , i click on that and it opens a webpage that says http://help.opera.com/opera/Windows/2393/en/ and its ALL in Japanese
              Instead of ME uninstalling anything , why doesn't Opera put things back the way they were , otherwise , i will just un-install Opera , and find something that isn't screwed up from a useless update that did nothing but cause issues with everything about Opera that WAS good
              All the websites mentioned , worked PERFECT before the Update , so its not a setting unless Opera changed the setting on its own , which is the point of my complaint post , it worked fine before and now its Junk .... seems simple enough , put it back to the last version and leave it till you can fix this version , then give US the OPTION of choosing weather WE want the change or not , and if not let us have the ability to revert back to the one that actually works !! , ......
              Since i am not the only one with this issue , i would say it needs to be FIXED and it is a Problem that whatever idiot
              made the update , because its clearly not working properly ....Google Chrome took away the Menu across the top ..I as well as countless others stopped using it , yet they don't care .... i hope Opera does not have the same attitude .............
                Also , i just looked in "Extensions" it says none are installed , so again , its not me that caused this
                This is what i see on the Help page
                ]＀￿￿￿ÿࠞم⢨夗꧙▧씾ͬ䃜ㆮ﨨ꥵɷ䁭랰콗䬏꧳␅윏瘿㾌䕽驀杫犐㿈댇죶嚞竨黢휑օﶔ嫥鯘ᅊ熯㵬廏僊颛◥ࡻ픩ឈậ잙酌␵⿍Ⲫ⨳蘉ꊟ눃檎úፆↇ嗂젲㌈⊟䮟邈햡‍誚鉣㗦ⵯ뺣჉쏗㌠饣㣫潹ᕏ溉ܻꓠ한⯴◁싙ⲽ갥အ桽ㆰꆝ悰䞮믯㈓꽐䋻乑᧻ↁↂ弾Ɽ磢�ȧ䪲㍭ᕤ闄젮᫾鍟팻芎ﺫ뎟᭞틱☷砤ₘ㭲㉷軷뎞빮良⥤랾챾돏䍶섭㩐聗펮�ᩳ�鄳ू㵱ண瘆뤚詨黝秳뼜饯�㞐풰竡㙱�뉟뺃霯纡ᙝ‹複禎耪‴鶡ᇜ⾼�啵倉꽀럇格偑짨꫸ꅯ⚽슡嶰⟜諌ૺ嚿䌥漍精Ѯ�閚䅑ŧԂ䎓�歮탞ﹶ爢挟澬‚嬦㷈鋝鄖䚦⋓暽鹕◤億Ù方㛤㹈Ȫ띃⾭璉荟竢鱴鑦瑃鏪瞚퇥ߞ뛗菓递Ɬ꧚᧔痁챥ᅲ궬ᢳ㈌呖㇈轜͌琉㉯꫙籏⻸ꭽ挧룸ᦾۑ㫙뷺符彾릖ﲘૐ氿鮻붬磬냺뮅屎��楡홧鷱㘓滻ꎳ�೎暖퍲앆ᐨ뭄颧ꎲ氪缈꽉蹧촦Ⓣ樛䀛⽻禤﬏콮༎ퟤϾ륇솃፤స�잪鹧겉놵ཾ그❝Შ䮾笋䄥㘟⯖鿑출ண䭧璤밆͟䖱ဝ᧝럱ေ⚁苉廘ໂ髌㱐 〤뷔䞞⛒ͫዋ殌祮腊ꢍ֎篎䆏繚᡻苘─귯鑊⮬蕼ᴟ㬙꜌䷵嬨ᚂ琿咛危䑗퀣꣐ꞎ돵쾟ຎ鏤쯯늜县쥔ⴕ蚤⡮㪐裝媻ㅨ鵺ぞ왕鲃᮷鑓楂䎓ɹ㳠꫒忎⸪ᓄ﹤䲃汝쳙鵥뾪῱騕ᐣ᪌윟ᅔ珱䠦싰㊌​ᆽᣏ곋䰃溏⿟凱쫟裎긷똖⯤ࢥ熨悵㑄艭歑∮禉醏鿟༊锽纱�㿲靣玪င힣ﳛ糩ℸ偹湋쇲鐘Ǽ⣕ѧ旡慀쥠᎐税�嗢쓫㻋쯵뢻镞뇮쉟ᢩḵﳧ�⣯즀敖ậ௰�ผኃ߸韅俕㭁菆榺巶䒘婟㩮潍飛㭶ꪑꟴ㟷奎揓謄䵯뱯 ⸺뀝ꄵ覙ꦬ껠匔�逇㫐ٰ뢀旭曙琪滴ᅥ΀൑ꨟ�㱱봴齘鉊力삗ꣴ煾鮍�䓼皢ピ̈́ⷎ숂ꋿⳗ罊撂㙦퉐陔蕖멾겗쯙操茶䭄㓃鸅흠銟쳬㺣뾹奋⡥똷驂Ҏ䒷㮔⋴䝸쭘㘿オᗛ见࢞偠杚埲䰥篈碈Ⰻힼ᤼喙贸ꫝ䣯਍溲輆㳚秹꺛�᳅븽㣸뗠ᩚ쬝韋连⎍팚扷ၠἺ鉶෎吮逆᳀觹劣䠖푮ᢢڧ겛ⓤ镅걹ᇠ⼿鏛륪ス⸆̏赗鿇岁悇㾯⹊⹢翴簍魴嬱㔶扉ᵨ踚�᳒蹴瘪䏱㱼抺梤篒䡓«㓈蒪Ꞝﵒ綏껁⌤蛀庬炖䤀푔漙�말퇴鋿鄝ᡓ袧車ꈳ⿞鐫䒤䗾隷뇇浶鯧뮠틌ᮦ綺崇凍Ⓩ궷뒟睎ꢥ듅늜㽌❫驪鑈邙㣄ꑣ墨ᖎ﫳奿驴䖣摔炿畆厁螬㼮ẖ뱰䝄ㄋ瘲㸕涣鿴쐄婴窖㼼ཛྷ꬟ᠺꪗ䄉⸁ᜏ㥞�㉝犇嶦�⹻ⶣ덑䏲挑麞ᖏ둞䨢䉴ᓌ灄嗜遾㼝㾞녀ꩶ啾郀튟鄏鲓贳ꮫ轍ᖱ䟻ᬸ黙�浍命紮ᨦ᧴浗叀诪嬌꒤歭䗲璇䂕�奏₋椦༅黕㌽녚⛑퐷朔쌀臒㞡�㵈躑堋郙턲堰㏋긱�ᵗ擦ཌྷ磟︔䨔ି졚훤䥌ꨨኌ耋ᅐ拏那閬쀐ᴗ었냶๨⣔리�ཹ흞臆穇㪭曃嶭䂬�Ꙟᯛᬬ㙈첬ᚖꀏ᨟뾻ꑣᾩ︶㜫↧튶彏砰甥๦꬐۶끅த蝊콫衈ⱟ䙵⻔ᯯ秝벌턣�樦촌堾损粇萈塜뭟퇥욌ꢉኹ둂鼵뗹ᖞ뜘幮齎믲쪫妦둀蹄彺蓌历㨦ﴨ≠訨ꚱ䦮읧�踚㫲꽊�ꑴ힭ﶾҌ椨쿮アኒ䂿䲧毩桡ǂ醩짪쟱◂䴦⿯䖒罡鰺氱阣㍳�㷻萝ᑧﲼ䅡갣碤柽길뭲芬⼃栩쭲ӥ윶菶蝣췱꼽녞迮駫㋎﫧ꒋኼ홓ۓ녠蓪Ꭺ롗앛쪨所�Ք㫐訞㽩⭶թ䡘␛쫠텍鶦៸剶稆敥㝓ﭟ㤫㘽➖ᣝ辙䏸沊ꭃ砱鱊姝顯䗆菩̬ꝿ弩�河Όᱽᅈ枴犻뾇Δ鏠퐠愪�䂲둤ᳩ툯᫓첎鎞咼餐뮰Ꭲ⁝�哏瀆禒뙕떏募센䲫怋䠩쎈䂑᠆곭᫒錸Ⱖ䁶ꈶ꽷ᥛ볟䙽쀊﫝㖅떄ჾ젺ừ턽�ᾭ䚉͍⤻魊稠셟혌䄁䍧쵿▲ꭁ뮛罣饼떍ྼﱝ渦맟鱣와염鵓䷎☖甃㿴�ՠ蔦遥ⶤ䶌喙�垭蟎냑⚚깴ꍫ㛋쬕⎫옳尥藳앞閮킳᠟臑亻㉧찕짿뵃눌㡾龩燎˘觐ᠴ戀쓦∛銻㠰⧇렜锺⪶꤆֕瓩㨣큀덍셱蓎鹢剨졵଩髙挅駊䇕ʅ嫊㑕뀉‍樤昷㬡ᗀ供袹ㆶ쯜㉔逦榣鍤㱙趽�ሡ텹=錆耓䊣謟ᎅ㵱陹袭澠聞㍻쵠᩿⎒ﻊ윲ካ₀浶㆗肂맗釯쯌捵좥⒮ए�㞩㹥갣秞鸫仭侒孲䉒䏃ᚠꈜᧈ嚞䙦⫐邊䎰훞羫䵷ऴ혅窱ŚD⓾咭஡뵼甪ា쭿䲔�㨈䱱ろ⹎᥍撢蔪眬胒猪榉㔛経㕍騴꽿腍뽺煋쒼윚ⷵ䀏嬨㪱寱ﰮ㦚擴⿗⪦묿甭滢˹珒෨岧潊棿綟폀졜ᴹഞ틵Ȉᦼ৯曰颩欅븮Ꮛ鑝练尚鮼ʍ쌢蔈ؤ‌쨏蹙掇㲋瀆슬ꜰ벞�䆨鐒ኆ쨏攜䦫녔쾭뮖钽팏ᩈ否퇼飓伟ݦ赬ਤɫ詸틺끜㌸꫔㡡滌悜ٯ䵓婓땶즶ഄ㦆ꚟ逐ᐌ愬淹起﵆䞽惕폹謟ῦጛ㚱䥱㧁铓춉᧫ꆴ⽳磲税冐膴れ턕쀽䑫熋ﴑ䩾菂로ท⤦ㄬ䐕ㆋ␩䐆哟땣ᓂ峩蛳۱㜐㞚⤸쮄⁴냬鼑议躩蘾䀞➹薃ꅨ軲⮨팠㿞袶亙꜂ꊌ㰲䍈꺙贇徇쟱澽俀Ỏ�쐅筑퇉ﺙ腨袨撢婳�鶔Ꞡ洗ꙉᆘ༛蟻樓ᦽଵ��饕髸뛨O駱㓾變ꗤ༳닃ᤄ돕㝐ၼ朇ᕊˬ텢
                  Dude, you need to chill out and treat those around you like human beings. If you were working customer support would you help someone acting the way you are acting right now? Or would you call over security to toss you out on your ear?
                    I did not cause this mess Opera did , sounds like you guys hang out with Google , i have a right to have a attitude , i didn't do anything wrong , and my rant is not directed at YOU , its directed at Opera and the idiot that released a Update without testing it or asking if WE wanted this change to garbage , Opera was my main browser till this , now i have to use Firefox to actually use any forum i frequent , so yea , i'm pissed ... if anyone needs toosed out on their ear its the programmer that screwed this up !!
                      Oh and would i help someone acting this way ?? , I sure would , i would be the first to jump on the programmers about what a mess they made and tell them we have people Pissed about it and it needs resolved .. and make sure the person complaining has these issues they WE caused FIXED ....
                        As far as treating people like Human Beings , i said nothing derogatory to anyone on here , so maybe YOU need to chill
                        All i did was complain about a issue that turned Opera to crap , how is that treating anyone directly bad ????????????
                        I said NOTHING directly to anyone , nor did i call anyone replying any names , this is a forum to lodge complaints and report issues , i am doing both
                          Well it loks like even EBay is screwed up looking , , not all websites are this way , but the majority of sites i frequent are (motorcycle forums , automotive forums , EBay etc) , i have not visited every site i frequent , so as mentioned , i will have to use Firefox and re-log into every site i use because of this crappy update caused issue , because it has made Opera almost completely useless for browsing .... This needs to be FIXED !!! , or plan on a mutiny of a majority of Opera users ....just sayin ....
                            Hopefully this shows what it looks like
                            eBay
                            Shop by category
                            Enter your search keyword
                            Search...
                            Search
                            Advanced
                            Hi Jim! Daily Deals Gift Cards Help & Contact
                            Sell My eBayExpand My eBay
                            Notification
                            My eBay: Summary
                            http://my.ebay.com/ws/eBayISAPI.dll?MyEbayBeta&mode=0&CurrentPage=MyeBayNextSummary&SubmitAction.GeneralSettingsUpdateAction=x&MyeBayDefaultPageDD=138jimdirt450
                            jimdirt450 (107
                            Tell us what you think
                            Activity
                            Summary
                            Watch
                            Sell
                            MessagesPage
                            Inbox
                            Sent
                            Unread
                            Flagged
                            AccountPage
                            Page options|
                            Summary page options
                            Show selling sections on my summary page* Sections without content won't be displayed
                            CancelApply
                            Summary is your My eBay homepage
                            Buying Reminders
                            Watched items ending
                            (2)Watched items ending
                            Navigation Menu
                            Summary - Current Page
                            BuyMenuBuy
                            Bids/Offers - Page
                            Didn't win - Page
                            Deleted - Page
                            Purchase history - Page
                            ListsMenuLists
                            All lists - Page
                            Watch list - Page
                            Wish list - Page
                            Your lists
                            Searches you follow - Page
                            Sellers you follow - Page
                            SellMenuSell
                            All Selling - Page
                            Scheduled - Page
                            Active - Page
                            Sold - Page
                            Unsold - Page
                            Shipping labels - Page
                            Returns - Page
                            Deleted - Page
                            Announcements
                            See all eBay announcements
                            eBay
                            Shop by category
                            Search...
                            Search
                            Advanced
                            Notification
                            My eBay: Summary
                            jimdirt450 (107
                            Activity
                            Summary
                            Watch
                            Sell
                            MessagesPage
                            Inbox
                            Sent
                            Unread
                            Flagged
                            AccountPage
                            Page options|
                            CancelApply
                            Buying Reminders
                            Navigation Menu
                            BuyMenuBuy
                            Bids/Offers - Page
                            Didn't win - Page
                            Deleted - Page
                            ListsMenuLists
                            All lists - Page
                            Watch list - Page
                            Wish list - Page
                            Your lists
                            SellMenuSell
                            All Selling - Page
                            Scheduled - Page
                            Active - Page
                            Sold - Page
                            Unsold - Page
                            Returns - Page
                            Deleted - Page
                            Announcements
                            Sorry, we couldn't complete your request. Try again later.
                            Additional site navigation
                            About eBay Announcements Community Security Center Resolution Center Seller Information Center Policies Affiliates Help & Contact Site Map
                            Copyright © 1995-2017 eBay Inc. All Rights Reserved. User Agreement, Privacy, Cookies and AdChoice
                              Well actually it looks worse than this shows , if that tells you anything , but aside from everything is just running down 1 side , instead of a jumbled up like this , but thats all i see , nothing but text on My Ebay homepage , so its definitely a issue
                                most every site i visit looks like this , now do you see why i am pissed ???
                                  Well, they are removing it and I don't think anything will change regarding it. So you will need to get used to it.
                                  About the bookmarks you had on it, aren't they in 'my bookmarks'?
                                  So far you seem to be the only one with this problem, so the chances of it being an Opera issue tends to be low.
                                  Do you se any security/privacy related software that may be blocking pages content?
                                  The /en in the page address shows that it's in English and a page in English is what I see here.
                                  Did you try to clean cache and cookies? What about a clean profile?
                                  Are you sure about that? Statistics show that 9 out of 10 people who come here ranting about issues like yours end finding out that it's not Opera's fault.
                                  Well, ranting is against the forum rules so you did - and I could say you are still doing - something wrong. So please calm down if you still want to be a member of this forum.
                                  Remember that this is an users'forum and ranting will only prevent other users to try to help you.
                                    Also , why are my posts being held for "moderation" ??? , this is crap , and the fact that your saying this is a USER forum ..... where are the people that work for Opera ???? , i guess they don't care enough about their product to take the time to see if people are having issues so they pass it on to the users ????? figures........ and i am not the only one with this issue , just go to the Opera for Windows forum and there are lots of posts jwith the EXACT same issues as mine ... maybe YOU should do some research before posting or blocking someone .....all YOUR doing is making matters worse by blocking me , YOU are about to lose Opera some users with YOUR attitude !!! this is BS .. a USER blocking me , where are the Opera Tech's that are supposed to be here ?????
                                      Your posts are being held because you posted ten posts in a row in quick succession, which is often a sign of spamming.
                                        Because the anti-spam system is catching them for some reason. Probably because there are lots of links on them. And also what Dave said.
                                        They may come here eventually but you should not expect any answers from them.
                                        They have more important things to do than deal with someone who acts like a spoiled child.
                                        The 'unsorted bookmarks'thing maybe but not the sites issues.
                                        If you are blocked, it will be because of your attitude and violation of the rules.
                                        No, I would be only taking care of the order here in the forums. You don't have the right to come here and do whatever you want.
                                        You will not be missed.
                                        a USER blocking me
                                        Not just an user but a moderator.
                                        They aren't, that's the point.
                                        Well, this discussion ends here. Depending on how you behave, you may be able to keep posting about your issue. Anything else will be removed and may lead to a ban.
                                          Back to the issue: did you test after have cleaned cache and cookies? Did you test with a clean Opera profile?
                                            Well like the update ....Thats just stupid , same crappy outlook to users as Google Chrome , looks like Opera is using them as a example on how to run a crappy browser....looks like Opera is going to be losing users , they just RUINED IT . and their Tech Support SUCKS , pretty sad when Users have to help people because the people who made the browser are too lazy or don't give a crap enough to do their job..... . looks like i will have to find a new browser that actually listens to people and doesn't make stupid changes without ASKING FIRST if we want a change , the Update just made Opera useless for me ,out of 50 web pages i have TRIED to visit today (sites i regularly visit that worked PERFECT till the update) , i can view about 10 normally , all the others are looking like what i posted , just gibberish and text ....Thanks for nothing Opera , Opera must work for Trump , just make stupid decisions without looking at the overall effect it has on everyone .....great so much for technology getting better.......i'm done with it till they put it back EXACTLY as it was before the crappy update/downgrade , if they don't , then its getting deleted , as its now Junk.... ....
