    How to know if the installed version of oper is native 64 bit or 32 bit running on top of 64 bit
      motagaly last edited by
      How to know if the installed version of Opera is native 64 bit or 32 bit running on top of 64 bit operating system (like in my case Windows 10 64 bit ?
      I looked into by Opera info and found out the below which means that it 32 bit running on 64 bit operating system as far as I know from my research on the Internet
      Rate Opera
      Version information
      Version: 42.0.2393.85 - Opera is up to date
      Update stream: Stable
      System: Windows 10 64-bit (WoW64)
      Browser identification
      Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/55.0.2883.75 Safari/537.36 OPR/42.0.2393.85
      Paths
      Install: C:\Program Files (x86)\Opera
      Profile: C:\Users\Ahmad\AppData\Roaming\Opera Software\Opera Stable
      Cache: C:\Users\Ahmad\AppData\Local\Opera Software\Opera Stable
        Check menu > about Opera. If 'browser identification' has 'wow64' on it then you are using a 32 bits version running on a 64 bits system.
