    How to post about a problem in Opera
    Opera for Mac
      If you would like to post about a issue you are facing in Opera, please make sure to include the following information as it will help other people in trying to check the problem and help you.
      • Topic title/subject (if you are opening a new one): It should be a short summary of the problem. Example: 'Can't play video on site xyz' or 'Opera crashes if I open settings page'
      In the topic body, include the following:
      • Description: Here you will describe what the problem is with the most details as possible but being objective and concise.
      • Steps to reproduce: Here you will show what people should do to try to reproduce the problem. Example: Go to page zyx; click on 'this', etc
      • Actual result: What do you see, what happens when you do the steps you have listed above
      • Expected result: What should be the correct behaviour when performing those steps
      • OS: Your Mac OS version
      • URL: If the problem is with a page, post its address here
      • Version of Opera: What Opera version you are using
