    [Solved]How To Restore A Speed Dial From Settings-Bookmarks-Other Speed Dials
    4708
      matthew1411 last edited by
      How To Restore A Speed Dial From Settings->Bookmarks->Other Speed Dials
      So in Other Speed Dials - we have a Speed Dial from another PC - shown here as Lenovo-AIO-700 - please see screenshot here - http://screencast.com/t/eHADAdj8wrag
      Is there a way to restore this particular Speed Dial to other PCs so that all of our PCs have the same Speed Dial dashboard?
      Thanks!
        Copy its content to the 'speed dial' folder. Do the same in all other computers that you want to have that Speed Dial.
          Thank you for taking the time to reply
          Not sure what you meant by 'copy its content' - but CTRL-A & CTRL-C of the Speed Dial we want to use - and CTRL-V into the destination Speed Dial doesn't work
          By what method did you mean to 'copy its content'?
          Thank you
            Ctrl C/Ctrl V should have worked.
            You are doing it in the 'Speed Dial'folder in bookmarks manager, right?
              Thank you for your reply
              Please see screencast showing CTRl-C/CTRL-V and its results
              http://screencast.com/t/bvbXMTLTCpMQ
                Here is a Jing video of what I am doing with Copy & Paste - and the results
                http://screencast.com/t/B0o0Ov5ZV7L5
                  You are not pasting it into the 'Speed Dial' folder in the bookmarks manager like was said.
                    Ah I see - now I got it - thank you for your help and patience
                    Much Appreciated
