    Fonts changed again and DirectWrite can't be disabled?
    • alobpreis
      alobpreis last edited by admin
      Just after upgrading to Opera 39 I started experiencing the same issue I had two years ago. Here's the thread:
      https://forums.opera.com/topic/5777/changed-fonts-in-some-sites
      Here's the screenshot if you don't want to click:
      Old versions, but the scenario hasn't changed. Opera 24 looking like Opera 38, and Opera 25 looking like Opera 39.
      Exactly the same problem, same sites, same fonts, but this time the DirectWrite option is not there among the advanced flags (opera://flags)...
      It seems it's an issue with Chrome as well. Check out this comment:
      https://productforums.google.com/d/msg/chrome/Q6QGBRvULbQ/lfe3Ot2ECAAJ
      So sad. 😞
        A Former User last edited by admin
        Probably because - GDI it's called? - they don't support it any more I heard (see here*. I suspect there's no third way left, thus no option.
        * From an older thread:
        Version 39.0.2256.4 fonts look ugly and small
        Check your zoom. What is it set at? What are your font settings? Try to change them.__ I just found out GDI font rendering has been removed from Chromium. It only renders with DirectWrite now. __Bad news for all browsers that are Chromium based.
          Yeah, code for GDI cals is removed from chromium. But text rendered through DirectDraw can be modified by Opera devs probably.
          https://msdn.microsoft.com/en-us/library/windows/desktop/dd368170(v=vs.85).aspx
          There are few modes of aliasing with DirectDraw which can be set.
          • alobpreis
            Meanwhile I reverted to previous version and renamed opera_autoupdate.exe.
              rseiler last edited by
              FYI, certain other browsers have kept it in/put it back. Example: Cent. And, I think, Slimjet.
