    Opera M2 Fonts size ( during in left & right viewing mode )
      emc last edited by
      Hello ,
      How I'm to customize the fonts size ( larger ) in M2 ( left & right view mode ) ?
      As each time when M2 starts, fonts on the right hand side are rather small.
      I already have tried in Preference , Fonts., but none of those seems work to the fonts size during left & right viewer mode.
      Thank you very much.
      Edmond.
        emc last edited by
        Anyone know how please .......... ?
          Right? You mean the message pane? The answer depends on whether the message is plain text or HTML. For text messages (no styling or formatting) go to Preferences > Advanced > Fonts and set the "Email display" font. HTML will depend on whether or not the sender chose a font of their own ... if they didn't, then Opera should use the "Webpage normal text" font. Yes, even though no size is shown in the list if you click on "Choose" you can change the size as well.
          The left pane (the list of messages) should use the "Browser dialogs" font. The leftmost panel with the list of views (aka access points) uses the "Browser panels" font.
            emc last edited by
            Thank you.
            You said....whether or not the sender chose a font of their own .....
            Right , and most senders using outlook mail client have their own set of fonts formatting.
            Does this mean Opera cannot set fonts size larger in the preference setting to these senders? I know I can assign keyboard shortcut to larger fonts on the mail body (the right hand side view pane)
            Just that I did not aware Opera could not take control on larger the font size by my desire default font size when sender using formatted fonts.
            Opera only can control sender who use plain text or non formatted text......that I can preset in preference setting.
            Thanks
            Edmond
