    60fps playback does not work
    Opera for Android
    2699
      Opera can't play 60fps videos on youtube.com, even my device support 60fps. It just play in x0.5 slowmotion and out of sync. 60fps works perfectly on youtube app and VLC player. the reason why i use youtube.com desktop version because some videos does not allow mobile viewing, so i stopped using Youtube app and use youtube.com instead
      Video to test: https://www.youtube.com/watch?v=QksH65BmjK4
        And what about in other browsers? Does the vide play in 60fps?
          Yes, 60fps playback works fine on Chrome and Firefox, but i prefer Opera because it has User agent
            How can someone check this? I couldn't find a way to see which resolution is being used.
              Click on the gear icon -> quality and select 720p 60.
              Make sure desktop mode is enabled
              i tested 60fps and Opera fail to test it. it trying to reach 57fps then instantly down to 37fps. It never happen on other browsers
              www.30vs60fps.com/
                www.30vs60fps.com/
                I tried this site and there is a message sayibg it wasn't made for mobile devices.
                Thanks.
                On Opera that gear icon seems to not appear, don't know the reason.
                  Ok, enabling desktop version fixed it. However, both in Chrome and Opera it shows a message warning me that my device can't run the page at minimum frame rate.
                    ok, how about youtube? and is there a way to enable Chromium video player on Opera?
                      In Chrome, enabling the desktop version, it shows me an option to see the video in 720 or 1080p in 60 fps. In Opera i can't see this option.
                      Nope.
