    Maximum number of columns on speed dial ignored
    Future releases
      I have my maximum number of columns set to 6, but there are only 5 columns on my speed dial. Does Opera modify the number of columns depending on the dimensions of the display? Or is something wrong here?
        Afaik, yes, the numbe of columns depends on the screen size.
          OK that would explain it. Too bad. Thanks anyways.
            velmont last edited by
            ... If the maximum columns worked then this wouldn't have changed anything anyway. If you had max 5 columns and it gave you 6 columns, that'd be a bug, no? What is it that you actually want? And why?
              Try using this Opera:flags and search for tile size decrease the tile size and it should make 6 columns
              here's the two links just copy paste into address bar and hit enter
              opera://flags/#default-tile-width
              opera://flags/#default-tile-height
