    Strange Problem - Delayed Response for Browsing
    Future releases
      scottmccarthy945 last edited by
      Guys, I need to know if anyone is having the same issue I am having. When I load Windows 8 or 10 and it's done booting, I will load Opera to browse and nothing will happen - it won't be able to browse or pull up a web page. If I wait 2-8 minutes, it will eventually start working. It seems like Opera just won't work for a while after Windows starts or comes out of sleep or hibernation.
      I have tried this on multiple computers and laptops and I get the same result.
        does this happen every time you restart the browser without rebooting?
          Is your network connected directly to your machine? There is some delay to establish the (wi-fi) connection on my machines - but only a few seconds. After that, if Sync is enabled Opera will be doing that - again usually just a few seconds. Extensions? Some of those do their own update checks or synchronization. Try disabling sync or a few extensions and see if it makes much difference.
