    Bookmark icon problem
    10477
      squickly last edited by
      Hello. For some reason the icon of one bookmark site shows incorrectly, instead to show icon of the website, it shows totally different icon (gmail one).. does anyone knows how to fix this problem with incorrect bookmarks icons? It's only for this one site.
        And can't you change it by opening the page and clicking on the heart button?
          Hmm, I don't see any option there to change the icon.
            Its the arrow buttons to the left and right of the image. It lets you cycle through a plain text based icon, a thumbnail icon and various images that are displayed on the page you are bookmarking.
              Yes I can cycle through it, but only that, no apply option or use this icon. Just cycle left right.
                There's no icon that was supposed to be the first time I bookmarked the site there. I cycled through it. Just some folder images... is there anywhere inside opera installation folder where I can try change this gmail icon for this website to it's original?
                  btw, when I reinstall Opera, the bookmarks have their original website icons, but after some time one of those icons change to gmail logo (M envelope).
                    The image you select will be the one used.
                      This is a public website? If so, can you share its address?
                        Yes, it's a warez website from my country, idk if linking such website is against the rules tho?
                          Here's the screenshots,
                          How it should be: http://i.imgur.com/f8HvtXE.png
                          How it's now: http://i.imgur.com/fLzQJ0p.png
                            Ah, you are talking about the bookmarks bar. I don't know how those favicons are get.
                              Ah, thats a favicon. Thats a different thing. I don't remember how thats handled but I do know its a difference process entirely. SOmeone else will have to chime in with a fix.
                                There aren't any Opera developers or someone from technical support here on forum to try and help? I wish I could contact them somehow.
                                  This is an users'forum although a few Opera emplyoees come here from time to time. I'm afraid you'll have to wait for someone who knows a possible solution.
                                  Opera doesn't offer individual support. You can report the problem so they can check and fix it, if it's the case.
                                    Okay, thanks.
                                      Very much the same problem here. I uploaded a pic for you to see (I also reported the bug).
                                      Thanks
                                      http://i.imgur.com/K0U5g8Q.jpg
