    Synced data & Passphrase problem
    Synchronization
      NiralParmar last edited by
      I remember my password & passphrase both but when I open my synced data it only shows "Information is encrypted" there is no option to decrypt data & see my information?
        leocg Moderator Volunteer @NiralParmar last edited by
        @NiralParmar You are looking at the wrong place, in sync.opera.com the information will always be encrypted and you will never be able to decrypt the information since the data is uploaded already encrypted.
        To get your data back, just login to Sync.
          N 1 Reply Last reply
          NiralParmar @leocg last edited by
          @leocg But I've already logged in + sync in turned on too but I can't see my old synced data that was encryted even tho it's visible in auth.opera.com showing "Information is encrypted"
            F leocg 2 Replies Last reply
            fitzydj @NiralParmar last edited by
            @NiralParmar is Sync everything checked in Operas Sync Settings?
              @NiralParmar What data you want to check? If you are looking for you bookmarks, go to the bookmarks page: If you need to see your passwords, go to the passwords manager page.
